Here are my install pics. I didn't get nearly detailed enough to do a How-To I had an appointment later that day, so I just didn't have the time to leisurely install them and get a lot of good "how-to" type of pictures. Hopefully though, the ballast and relay locations will be helpful to some down the road.
*ATTENTION: The passenger-side low-beam ballast (mounted on the air box) is a temporary mounting location. As my appointment time neared I just quickly picked a spot and mounted it quickly. It will be relocated soon.
3 of the 4 ballasts are bolted down and the 4th (which is temporarily mounted) is screwed down -- no double-sided tape for me; I just don't trust it with all the elements that can encounter it.
All wiring is mounted with zip-ties and relay ground properly grounded (LOL).
Bumper Removal -- this I did take enough pics to do a step-by-step How-To. The picture progression follows Kyle's written How-To. This was my first time removing the bumper and it was cake! Took 10 minutes to remove it and about6-7 to replace it. Super easy!
Forgot to take pics of the grille removal, but it's easy -- remove the 6 plugs that hold it in and then pull up and away at the same time.
Xentec HID Slim Ballast Fog Installation -- each ballast is bolted the metal frame that the front bumper attaches to. The fogs are a very easy installation and do not require the removal of the front bumper, but it did make it a helluva lot easier; definitely recommend it!
Pictures begin with the driver-side fog and then move to the passenger-side fog.
...continued...
...continued...
