Home Forums Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Notices
Performance Modifications Make your Jeep perform and ride better!
Go Back   JeepGarage.org - We Are Jeep! > Modifications & Enhancements > Performance Modifications
Reply
Thread Tools Display Modes
  #1
Old 10-26-2009, 07:40 AM
Tim@NCTSLLC's Avatar
Tim@NCTSLLC Tim@NCTSLLC is offline
Vendor
Tim@NCTSLLC has a spectacular aura aboutTim@NCTSLLC has a spectacular aura about
Default Switch to disconnect the ABS pump fuse
This weekend I hooked up a 12v relay and an in cab switch to allow mw to have push button convenience to disconnect the ABS pump fuse.
Here is what you will need.
One - 12 VDC Automotive 5-Pin Relay SPDT 30/40A
Two – 14/16 AWG (Blue) Male spade lug
Four – 14/16 AWG (blue) Female Spade lug
Two – 16/18 AWG (red) Female spade lug
One – 16/18 AWG (red) ¼” post ring tongue lug
One – 16/18 AWG (red) #6 post ring tongue lug
One – #6 x 3/8 self tapping screw
Three – 6” long #14 AWG Red conductor
One – 24” long #18 AWG Red conductor
One – 48” long #18 AWG Black conductor
One – 24” long #18 AWG Black conductor
One – Push button or toggle switch (only needs to be rated at 1 – 3 amps)
Electrical tape or heat shrink.
Solder or additional lugs to connect to your switch.
Depending on the relay, either cut off the plastic mounting tab, or remove the metal mounting tab from the slots on the relay so it will fit neatly down in the slot next to where you will remove the fuse.
The relay will have five terminals marked 30, 85, 86, 87A and 87.
Make sure the relay has the post configuration above or it will not function correctly!
The 87 terminal is NOT used for this installation, when the relay is activated, this terminal will have 12v positive power on it, so it could be used to light an indicator light to alert you to switch position if desired.
Installation
Remove the ABS Pump fuse from the power distribution center under the hood. This should be a pink 30 AMP cartridge fuse. Check your owner’s manual to identify the correct fuse; it will be listed as for the “ABS Pump”
Take the two 6” long red conductors, and crimp a female spade lug on one side, and a male spade lug on the other side of each of the conductors.
Plug the male spade lugs into the sockets on the bottom of the pink cartridge fuse you removed.
Tape or apply heat shrink over the connector’s and fuse body for protection and to prevent the lugs from being dislodged from the fuse.
Plug one conductor into a male spade sticking up in the fuse box where the cartridge fuse was removed.
Plug the other end of the second conductor on the 87A terminal on the relay.
Take the remaining 6” long conductor, and crimp a female spade lug on each end.
Plug one end of the conductor into the other male spade sticking up in the fuse box where the cartridge fuse was removed.
Plug the other end of the conductor on the 30 terminal on the relay.
Take the 18” long black conductor and crimp the #6 stud ring tongue lug on one end. Connect the other end to your switch (either a lug or solder depending on the switch).
Take the 48” long black conductor and attach to the other terminal on your switch (either a lug or solder depending on the switch).
Mount the switch in your desired location.
Attach the end of the 18” black conductor with the #6 ring tongue lug to a ground using the self tapping screw or an existing screw under the dash (must be a solid ground).
Route the long black conductor out through the fire wall and to the power distribution center.
After routing to the fuse box area, trim off any excess so that it comes up in the open area of the fuse box from underneath (space is next to where you removed the fuse), and crimp on a red female spade lug.
Connect the black conductor to either the number 85 or 86 terminal (makes no difference) on the relay.
Take the 24” long red conductor, install a red female spade lug on one end, and connect to the 85 or 86 terminal on the relay (the one you did not use above).
Route the lead out of the fuse box from underneath and over to the 12V post on the battery.
Trim the conductor to length and install the blue ¼” post ring tongue lug.
Attach the lug to the battery post by removing the 10MM nut and placing the ring lug under the nut.
Retighten securely.
Test the relay.
Make sure your switch is in the OPEN (off) position with the relay de-energized. This is the normal everyday driving state.
Start the vehicle and verify that there are no dash indicator lights on for ESP, ABS, and BAS.
Change the switch position to the CLOSED (on) position, and verify that the three indicator lights for ESP, ABS, and BAS illuminate on the dash. If so, the installation functions correctly. If not, recheck your wiring.
Place the switch in the OPEN (off) position and turn the vehicle off.
Note, that the dash lights will stay illuminated; we will cover that in a moment.
Neatly route the wiring down into the open slot in the power distribution center along with the fuse and the relay. Refer to the photos.
Close the lid and you are done.
Now, how the switch functions.
Whenever you place the switch in the CLOSED (on) position, you energize the relay which breaks the connection for the ABS pump fuse. It is best to do this with the key off, but if need be, you can do this with the vehicle running.
When you activate the relay, all three lights will illuminate on the dash indicating that ESP, ABS, and BAS are disabled.
In normal driving on dry pavement, you are unlikely to notice any difference in your braking abilities other than ABS will not activate.
To restore operation, turn the switch to the OPEN (off) position to de-energize the relay. You must cycle the ignition key off, restart the vehicle, and drive a few feet forward and the indicator lights will go out indicating that system operation has been restored.
I do not advise ever using this anywhere but at the race track, and NEVER use this in inclement weather, as your ability to control the vehicle in slippery conditions will be greatly impaired.
USE AT YOUR OWN RISK!
I will add some pictures later this evening.
__________________
Turbocharger systems for the Modern MoPar
Visit us at http://www.northcoastturbosystems.com and http://www.iems3.com for the latest in engine management system integration with your factory ECU.
Home of the fastest 5.7 Cherokee, First 5.7 Cherokee to break into the 13's.
Best 0-60 MPH in 4.18 seconds! All stock internals 5.7 Hemi with a bolt on turbo! Tuned via the iEMS3
Sharadon Performance Valve Body
  #2
Old 10-26-2009, 07:52 AM
HEMIBeast's Avatar
HEMIBeast HEMIBeast is offline
Built "Beast" tough
HEMIBeast has much to be proud ofHEMIBeast has much to be proud ofHEMIBeast has much to be proud ofHEMIBeast has much to be proud ofHEMIBeast has much to be proud ofHEMIBeast has much to be proud ofHEMIBeast has much to be proud ofHEMIBeast has much to be proud of
Default Re: Switch to disconnect the ABS pump fuse
Awesome write up!
__________________
JEEP GC Limited 5.7
180°Tstat,Flyin Ryan ported throttle body,Bwoody CAI,MHP CMR Tune Predator 7137,Billet tech catch can,Dynomax muffler, AR Headers,5" blk tips,CF Rammedic Hood,SRT8 Exterior,SRT8 Rails,SRT8 Grille,Custom headlight covers,Tinted Tails (Red03SilSS),Tinted windows, painted mirror covers, Painted & Shaved door Molding,Mopar Rear spoiler,painted black calipers,Black housing headlights with LED Halo's & controller,8000K H.I.D,Reverse H.I.D,20" Black SRT8 rep wheels,Falken Ziex 275/45/20,Addco Front Sway bar,SRT8 Rear sway bar,H&R Springs,Leather Armrest,SRT8 pedals,SRT8 Shift knob,Colored cupholder,2 pod A pillar w/ Gauges,etc..
Parts awaiting install Spartan Cam, 09 Intake manifold, etc.
  #3
Old 10-26-2009, 08:15 AM
Joe in PA's Avatar
Joe in PA Joe in PA is offline
Prone to posting while only half awake .....
My Jeep: 2004 4.7L WJ
Joe in PA has disabled reputation
Sweet write up!
__________________
01' WJ Larado - 4.0L i6
04' WJ Freedom Edition - 4.7L HO
07' WK Limited - 5.7L Hemi
09' Mustang GT - Good For the Soul
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
switch to synthetic oil B.P.O.D Grand Cherokee - WK 27 10-01-2009 11:41 AM
Labor Day Water pump Nightmare 1054EDP Grand Cherokee - WJ 11 09-10-2009 07:57 AM
Fog lamps out... fuse? Matt Troubleshooting/Problems Discussion 39 09-04-2009 09:01 AM
Blowing 10amp Parking fuse w/LED's??? TimmyB Visual Modifications 24 06-15-2009 03:29 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2009 - JeepGarage.org
We Are JEEP!
